P0107 and Service Traction/ESC ESC Off??
Old May 18, 2017 | 12:54 AM
zKabi's Avatar
I replaced the air filter on my 2009 HHR 2.2 and after installing I got them error codes. They stay permanent and after clearing the code, it pops right back up. I don't understand because everything was fine before the replacement...
Old May 18, 2017 | 06:52 AM
What are the codes?
Did you reconnect the MAF sensor?
Old May 18, 2017 | 08:13 AM
You forgot to reconnect the MAF sensor like everybody. Or the wires are damaged, or just not clicked in.
Old May 18, 2017 | 11:14 PM
zKabi's Avatar
Originally Posted by Oldblue
What are the codes?
P0107 MAP Sensor, Low Voltage
Yes I have connected the MAF sensor (The one connected to the engine cover) and checked multiple times. I even unplugged the sensor while it was running and the hhr immediately shuts down.
Old May 18, 2017 | 11:17 PM
zKabi's Avatar
Would the wires still be damaged if the MAF sensor is still working?
Old May 19, 2017 | 08:41 AM
It is not working. That's why the CEL and code.
Did you touch the MAF or drop it?
It should not stall if you disconnect it, maybe wires are frayed and touching?
Check fuse #33 underhood fuse box.
Old May 19, 2017 | 10:17 AM
zKabi's Avatar
Fuse 33 is intact. If its the MAF sensor, code P0102 should pop up right? I have code P0107 which is for the actual MAP sensor.
Old May 19, 2017 | 10:32 AM
You are correct! I was thinking too fast.
I suspect something is shorting the 5V ref wire.
This link has testing procedures: https://www.obd-codes.com/p0107
Check the MAF connector.
Check the wire bundle at the EVAP purge valve.
P0107 and Service Traction/ESC ESC Off??-wire.png
Old May 19, 2017 | 10:44 AM
zKabi's Avatar
Attachment 21647
Is it ok to just buy one of them cheap multimeters from walmart, and how can I go about checking the vacuum without a vacuum pump?
Old May 19, 2017 | 01:05 PM
I would do the wiggle test. You will need a digitalVOM, most are now, Harbor Freight sells them for less than $10.
