Esc Active Always, can't turn it off. HELP
Old Dec 6, 2024 | 09:22 AM
MebbyVester's Avatar
Hello, 2011 HHR LT 2.2
So we've had trouble with the front end, changed both axles, hub assembly and inner tie rod on drivers side. But each time we changed something, what we felt and heard would stop till we got on the road and hit a certain speed then it would start again.
Not too long ago we noticed ESC Active coming on. Figured that's was the problem all along. Tried resetting the system by touching the pos and neg of the battery connections together, also tried turning ESC off. It will not go off.
At random times ESC will slow the car down to 20mph then let driver have control again, also it is pushing breaks at random even going down a straight road.
Please help if you can. Thank you
Old Dec 6, 2024 | 09:36 AM
CheckEngineLight? Accidents? Rear hubs?
DON'T TOUCH THE NEG AND POS TOGETHER. Disconnecting the negative post is good enough. I am assuming that you know the battery is near the spare tire, not the black box under the hood.
Old Dec 6, 2024 | 09:43 AM
Check engine light is rare. No accidents that I know of. We havent checked the rear hubs... should I?
Old Dec 6, 2024 | 09:44 AM
Yes i do know that about the battery. Very odd placement lol
Old Dec 6, 2024 | 11:53 AM
Check the front hubs and LCA’s
Old Dec 6, 2024 | 02:55 PM
My boyfriend knows cars pretty good and the lcas are the only thing he hasn't changed, but he said the look intact. We really think the cause of everything has to do with the ESC
Old Dec 6, 2024 | 03:00 PM
The rear hubs have wheel speed sensors; if 1 or more wheels tell the computer it is turning at a different speed than the others ESC is activated.
If the computer think the car is going in a different direction than the steering wheel is turned to the ESC gets activated. There is steering angle sensor and a lateral acceleration sensor involved. The EBCM is the computer that controls ABS and ESC.
Old Dec 6, 2024 | 03:23 PM
Get the popcorn and watch the video
Old Dec 6, 2024 | 05:03 PM
Hiding codes does not fix anything!!!!!!!! I think that vid is malpractice and should be deleted from youtube.
The reason his ESC and Traction was on is the P0013 and/or some of the other codes he is irresponsibly hiding in order to cheat someone.
He is a total idiot.
Old Dec 7, 2024 | 07:18 AM
Video deleted
Gearhead1
Aug 30, 2023 11:45 AM
Beejmamdude
Maintenance and Upkeep
Jun 20, 2023 01:46 PM
HHR 2.0
7
Oct 30, 2015 08:33 PM
tonajim
Dec 22, 2013 02:59 PM
harleyross
Jul 9, 2010 02:36 PM
