Feels like I'm driving in the wrong gear.
Old Jan 9, 2017 | 07:07 PM
Moved to appropriate area.
Old Jan 10, 2017 | 04:52 PM
Sydnika's Avatar
Still no answer to post #4. Guess I'm done.
Fwiw. I highly doubt you replaced the camshaft. Camshaft position solenoid maybe. 2 completely different parts.
Why ask me what I did and then when I say what I had done to my car! You highly doubt I did that??
Old Jan 10, 2017 | 05:14 PM
Because nobody here has ever heard of anybody replacing "the" camshaft on account of there are 2 of them and mostly because replacing both camshafts would cost as much as replacing the entire engine?
If you actually did, why? Nothing you have said here would indicate the need to. Which one? How about the timing chain and guides? How about the chain tensioners? What caused "the" camshaft to malfunction, was that fixed?
Old Jan 10, 2017 | 05:28 PM
Sydnika's Avatar
Your opinion isn't needed... So when You see Sydnika post a thread don't comment. Thanks. Have a great day
Old Jan 10, 2017 | 05:44 PM
I'll respond since it was directed at me.
I said I doubt it was a camshaft because that is a major part of the internals of the engine. Besides, there are 2 camshafts (your engine is a double overhead camshaft engine).
I think you just misspoke about the part. It was probably the camshaft actuator solenoid. That part is just a sensor so to speak and easily replaced.
Now camshafts themselves, that would involve major engine repair. AND would be very costly.
As far as your current issue. We've tried to ask you questions about your problem. You haven't answered those. It would help us narrow down what the cause may be.
Heck. If you're anywhere near me in Alabama, I wouldn't mind having a look at the car. Pretty sure I could tell you what the problem is.
Fwiw. I wouldn't try to shun Donbrew. He's one of our best technical gurus. He's got loads of info and can find an answer when others can't.
Old Jan 10, 2017 | 05:51 PM
Alrighty then we're done. Thread closed!
Old Jan 10, 2017 | 06:40 PM
If you knew the difference between an opinion and a clarification I might care.
I won't be worrying about seeing a Sydnika owned thread, I'll just delete it and ban Sydnika.
Ryan Beam
Aug 17, 2016 09:11 AM
BlackHHR Music Machine
2.4L Performance Tech
78
Mar 28, 2015 06:07 PM
redridehhr
Jan 24, 2013 12:14 AM
pitbull76
14
Mar 24, 2012 03:20 PM
dbfruth
Jul 8, 2008 07:21 PM
