Flickering headlights and all Cabin lights during idle
Old 01-14-2017, 03:41 PM
Keenan2789's Avatar
My headlights and cabin lights have suddenly started to flicker at idle. I've had both the battery and alternated tested and both came back normal. Not sure what the problem is, any insight?
No other issues such as crank, power, etc.
2006 2.2L
Keenan2789 is offline
Old 01-14-2017, 03:55 PM
Maybe a loose connection, fusebox halves, or ground.
RJ_RS_SS_350 is offline
Old 01-14-2017, 05:21 PM
I'd throw a voltmeter across the power connection on the dash below the heater controls, to monitor the voltage while stationary and mobile.
whopper is offline
Old 01-14-2017, 05:47 PM
failing alternator, low idle.
donbrew is offline
Old 01-14-2017, 07:25 PM
aradmahogany's Avatar
Yes. Alternator is probably on its way out. Mine did the same thing for a year before the alternator revealed itself as the culprit. I was gonna say something but wanted one of the all knowing gurus to confirm my assumption before leading you astray lol. If you replace the alternator give it a Happy New battery to charge too!!
aradmahogany is offline
Old 01-14-2017, 07:54 PM
He said the battery and alternator both tested good.
Old 01-14-2017, 08:38 PM
Loose grounds
Oldblue is offline
Old 01-14-2017, 09:55 PM
Maybe I'm just too old, but I can't think of a scenario that the charging system could check out good when the lights are flickering at idle.
The idle is too low for the alternator the provide sufficient juice. That could be that the alternator is not functioning properly at a normal idle or that the idle is lower than it should be, for some reason. There is a tachometer right on the dashboard, it should be steady.
The description that it is always flickering at idle and always clears up a speed means that it is not intermittent.
donbrew is offline
Old 01-14-2017, 10:21 PM
Keenan2789's Avatar
Here's a video of it
Also it's does not go away with speed I was wrong
Also test receipt photos:
Old 01-15-2017, 01:11 AM
Battery voltage is low (12.2) - and CCA is low as well. with the voltage dropping below 10V on starting (it actually dropped below 9V according to the graph), I'd replace the battery.
whopper is offline
Quick Reply: Flickering headlights and all Cabin lights during idle
