Front end clunky noise
Old Feb 14, 2013 | 10:54 AM
Ron S's Avatar
Are the swaybar bushings covered by the powertrain warrenty?
Thanks
Ron
Old Feb 14, 2013 | 11:08 AM
Snoopy's Avatar
Thanks
Ron
NO...it's NOT part of the powertrain !!
Old Feb 16, 2013 | 08:32 AM
Beaglelover's Avatar
Check swaybar bushings first!
Our 07 LT2 has developed the familiar clunking noise. We just turned 84,000 miles. Went to a suspension/transmission specialist yesterday and had it diagnosed as worn out front swaybar bushings. Repair is gonna run about $200.00, most of it being (naturally) the labor charge. The rest of the undercarriage looks great. The previous owner had some suspension work already done, so this repair had better be ALL it needs.
Old Feb 16, 2013 | 10:19 AM
Slide_Rite's Avatar
If you want to do it yourself...
If you or someone you know is mechanically inclined, it can be done relatively quickly and easily depending on your skill level. Here is a link, go to post #6 and beyond.
https://www.chevyhhr.net/forums/show...=sway+bushings
Old Feb 16, 2013 | 10:22 AM
F-16C's Avatar
Your front bumper cover could be loose. Grab it and try to move it up and down. Mine was loose and I tighted it up. much better.
Old Feb 17, 2013 | 04:00 AM
MCHHR's Avatar
I'm chiming in my $.02 here as I fought this problem for a few years from 30k until 110k miles. A Chevy mechanic had told me this is a common problem and they have to change parts until the noise goes away. Here's what we did in order:
1. Replaced all 4 struts including mount hardware/bump stops and sway bar end links (or so I thought)....noise still existed
2. Replaced lower control arm vertical bushings....noise still existed
3. Replaced sway bar bushings that run under the car....noise still existed
4. While working on driver side with tire off, noticed the sway bar end link was still factory. Mechanic didn't replace it, just the passenger side. Visually it seemed ok, but upon further inspection when trying to remove it, the 17mm nuts attached to the threaded bolt were worn down to no chance of getting a wrench on them to remove. Was able to vice grip and remove the outside nut...took a long time. Slapped on a moog with grease zerks....noise GONE!!!
The sway bar end links were around $38/ea and can be done fairly easily by any DIYer. The only issue is the clearance to the bottom nut. Prepare for some 1/4" at a time turns .
Old Feb 17, 2013 | 04:43 AM
DaGrinch's Avatar
I'd be going back to wherever to have a talk with someone about the end link that was supposedly replaced with the struts! That's ridiculous.
Had the clunking noise on my 2008 2LT and started with the little things first, then was going to work up to struts. After purchasing less than $100 in parts (Moog end links and Energy Suspension greasable sway bar bushings) and $50 labor to my freelance mechanic, the clunking was gone. So, it doesn't necessarily have to be an expensive, hair extracting experience.
Old Feb 17, 2013 | 12:33 PM
Snoopy's Avatar
Are you saying you replaced both front struts twice and the noise still existed. I would think that after a one time change of both struts, you would have an answer.
Also agree with the comment above this.
Edit: Oh, after rereading your comment I think you meant the front struts and the rear SHOCKS (for a total of 4....the rear are shocks NOT struts). But why change the rear components if the clunking was coming from the front (unless of course they were needing a change)?
Old Feb 20, 2013 | 05:31 PM
photojoed80's Avatar
Those noises will NEVER go away. No amount of time, money or patience will pay off. My '07 , as much as I love it will be my last GM car. The front end has problems and weak brakes have sucked much of the enjoyment out of the car. It still looks brand new at least.
Old Feb 21, 2013 | 04:07 PM
MCHHR's Avatar
I have a bad habit of using the word strut to refer to both struts and shocks . No real reason for changing the rear shocks. Guess I just wanted to since the front struts were going to be new...
I wasn't mad at the mechanic at all. He's always been a good guy/family friend and doesn't go overboard on labor. As long as I get the parts I want, he'll do it for near nothing. Hell, I had him drop a new engine in a Cavalier I had and he charged $150 to do it. He knew a guy who had a Cavi rear ended and got the motor for $350. Had around 65k miles. I don't think he'd be the type to overlook replacing both end links. I'm sure he felt the driver one was in good shape for some reason. Even though I found replacing it did the trick, I'm not mad. It was almost 3 years ago.
