Front end rattle.
Not stumped any more.
There wasn't a change when I changed the column. It did change when I installed the used intermediate shaft. It seems there might not be enough clamping from the lower connector or not enough engagement. I ordered a new intermediate shaft but it came in wrong. I'm still waiting on a replacement.
As I recall there was an updated part to the intermediate shaft.
Not sure if they changed the part number or not.
Get the Parts manager and see what he can find out .
You sure don't need an old part that was left in stock.
Silverfox
Silverfox
I've read that if you take out the power steering fuse the rattle would stop. I did it. It did stop. It rattles in my asphalt driveway, slow speeds. Fuse back in? Rattled again.
I have an '07 LS, with only 83,000 miles, it was a highway patrol unit in Ft. Lauderdale, until I bought it in May, 2021. Well maintained with new LCA's, sway bar ends, etc. See previous post for front end rattles.
FYI, I'm still looking for the answer to this issue.
You can put multiple sentences in one post.
Do you know that the power steering motor is covered by a lifetime extended warranty?
My guess is that if turning the EPS off cures the rattle the problem is the intermediate shaft, the part talked about previously in this thread. If not that is must be the rack & pinion.
Some solutions and instructions to investigate rattles and clunks in here
https://www.chevyhhr.net/forums/prob...g-pop-s-50648/
