front end shimmy @60 MPH
Old Sep 9, 2010 | 08:53 AM
mudbilly's Avatar
My car has recently began to shake around 60 MPH............I took it to a local shop (my last resort is going to be going to the dealer becasue i have had issues there) and had all the wheels spin balanced, but the problem is still there.....
The wheels nuts are torqued correctly.
the mechanic cannot determine the cause.........
any thoughts ?
thanks
2006 LT . owned from new........new aftermarket brakes and pads installed a year ago, left front bearing assembly replaced 4 months ago
Old Sep 9, 2010 | 09:01 AM
Doc brown's Avatar
Could be a bad belt in one of your tires. Rotate them to see if there's a difference. Aside from that, it is very possible, however much you trust your local shop, that there is still a wheel that is not balanced correctly. I've had both of these scenarios occur more than once over the years.
Old Sep 9, 2010 | 09:05 AM
I was going to suggest tire rotation too, front to back, and see if anything changes.
Old Sep 9, 2010 | 11:26 AM
Snoopy's Avatar
Questions.......
Do you have stock/OEM wheels?
When did the shimmy start? After ANY installations?
LawDog88
Nov 29, 2014 09:07 PM
ashleighjbm
May 17, 2014 06:04 PM
gouldje
Jun 29, 2009 09:19 PM
HHRvey
2.2L Performance Tech
Nov 13, 2008 06:51 AM
SCOOT
Jun 20, 2008 01:44 PM
