Fuel Pump install....soon
No offense taken, I simply don't think that a metal plate with 4 screws to hold it down in the floor would cost very much.
Ok, I’ll take a gander at this.
The fuel tank is located beneath the rear seat, so an access panel to the fuel pump assembly in the tank would only be assessable with the rear seat lifted or removed. Plus another access method through the carpet to the desired sheet metal access panel would be required.
After doing all this access work, dropping the tank may just be easier.
