Fuel pump problems?
Old May 10, 2020 | 12:26 PM
nashsclay's Avatar
Fuel pump problems?
Originally Posted by Mrjustfixit
Oh yeah... After driving, pressure is 50psi but when shut off pressure drop to o psi in about 15 seconds.
Did your fuel pump sound pretty loud, almost like priming while driving? Mine is not having that bad of a drop but slowly drops and gets to about 20 psi in a few seconds after the initial prime when you turn your key to the position before cranking the engine. I replaced my fuel pump and my new one is constantly loud and almost priming while I drive. During engine run, it holds pressure nicely so I'm sure I have a leak maybe didn't get the circular plate above the fuel pump not 100 seated well. But let me know if yours is making that same noise.
Old May 10, 2020 | 01:47 PM
The fuel pump will run while the engine is running , what brand pump did you get?
Old May 10, 2020 | 02:17 PM
nashsclay's Avatar
Got a Delphi. But ya the fact it looses pressure instantly after primed, that's odd. Let me know if I should do a new thread so I don't take over this one.
Old May 10, 2020 | 06:34 PM
I’ve moved it to it’s own thread
Old May 10, 2020 | 07:36 PM
nashsclay's Avatar
Ok I made a video to show exactly what is going on. It's holding pressure better after I dropped the tank again today and reinstalled everything. But it's still making an almost priming sound when the engine is running which it shouldn't be that loud. When I turn off the engine it drops to about 40 psi and stays there for a little while and slowly drops. Not sure if the two issues are connected or not. I did take a video of the pump when primed with the pressure.
https://photos.app.goo.gl/pM4eUwheqexN2hFXA
Mrjustfixit
May 7, 2020 06:10 AM
Ijazzu
May 5, 2015 01:29 PM
Fievel4
Fuel Economy - Hypermiling
Jan 5, 2015 03:42 PM
ald
Jun 23, 2013 09:36 PM
crresind
Feb 13, 2013 11:46 AM
