Fuse/Relay
Old Jul 29, 2024 | 01:54 PM
Relay is #34 in the under hood fuse box
Old Jul 29, 2024 | 07:46 PM
I told you where to look for the diagrams that show you exactly where all of the fuses and relays are. Take the cover off of the fuse box turn it over and gaze at the picture. If somebody has removed that then download the Owner Manual from the link in my sig. https://www.chevrolet.com/support/ve...manuals-guides
Or, you could look in the Owner Manual that should have come with your car.
Old Jul 29, 2024 | 08:35 PM
kathy85's Avatar
Thankyou, I checked it and It doesnt light up but it doesn't look blown.
Old Jul 29, 2024 | 08:36 PM
kathy85's Avatar
I will do that thankyou!
Old Jul 29, 2024 | 09:28 PM
Why would it light up? That's not what fuses or relays do.
Old Jul 30, 2024 | 12:08 AM
kathy85's Avatar
I apologize I mean the pen I use to check the fuses light up when I check them
sorry I'm bad at explaining car stuff.
Old Jul 30, 2024 | 07:20 AM
I understand, the test light you mean.
Old Jul 30, 2024 | 03:04 PM
kathy85's Avatar
Yes that's what I meant.
Old Jul 30, 2024 | 03:41 PM
So you need that replaced?
Old Jul 30, 2024 | 08:47 PM
There should be a few of each type of relay in the fuse block. You could try swapping with a known good one.
I'm not sure that all relays and fuses are "hot at all times ".
