Growling when engine braking, louder when turning
Old Oct 22, 2024 | 01:47 AM
7eus's Avatar
When engine braking, I hear a loud growling/buzzing noise from the engine bay. It’s very deep and loud, not an electrical buzz. It increases in volume significantly if I’m turning as I’m engine braking. It only makes this noise in these conditions with no other symptoms than the noise. The front hubs, rotors, pads, control arms, tie rods, and shocks are all relatively new. This issue never went away as I replaced these parts. Any advice?
No codes present
Old Oct 22, 2024 | 02:23 AM
What exactly do you mean by engine braking ?
Old Oct 22, 2024 | 11:42 AM
7eus's Avatar
Shifting into I or L on the automatic transmission down a steep grade
Old Oct 22, 2024 | 06:07 PM
Doing that could be the the engine, like the timing chain.
Old Oct 22, 2024 | 06:32 PM
“It increases in volume significantly if I’m turning as I’m engine braking. “
No codes present
Honestly. I don’t have a clue what it could be. Never heard a description like that before.
Old Oct 22, 2024 | 07:45 PM
7eus's Avatar
Thanks anyways. I tried to recreate the problem again to take a video but too much background noise. I think the sound might be more like transmission area. My guess is that it’s something in the transmission or torque converter when the force on it is “backwards” during engine braking. I’ll try checking all the mounts when I can get to a lift.
Old Oct 25, 2024 | 06:29 AM
geg's Avatar
geg
does it sound like an engine at high revs?
Engine braking on an automatic transmission is an amazing technique, usually engine braking is practiced for a manual transmission, but if you use it, then this is your choice.
To the point:
As soon as the driver stops pressing the gas pedal, no fuel is supplied to the engine. At the same time, the inertial force acts on the crankshaft, causing a decrease in revs. Thus, the opposite effect occurs when energy is transferred from the wheels through the transmission to the engine. The crankshaft does forced work, the compression in the cylinders increases and the speed of the vehicle drops. If at this time the transmission is shifted to a lower gear, the braking effect will increase, although the revs will increase slightly - the crankshaft will be forced to spin faster and do even harder work, increasing the degree of braking.
I think that this is exactly the hellish work of the engine that you hear from under the hood. The loaded engine begins to "scream" from the strain. How the automatic transmission behaves at this time, only the devil knows. But there is a feeling that such a load is not good for the unit. I sometimes use a vehicle with a manual transmission and on such trips I use both engine braking and other techniques associated with downshifting. When I bought my Chevrolet with an automatic, I tried engine braking. The effect is weak, the automatic transmission is too slow to react, it takes almost half a second before the transmission figures out what's what and starts to react. Anyway, I tried it and never did it again.
Old Oct 29, 2024 | 02:10 PM
My bet is hubs or LCA bushings.
Old Oct 30, 2024 | 07:12 PM
Bonez's Avatar
bet its a rear hub... replaced everything on my front end and still does it, I thought it was a front hub, wife says its coming from the rear on passenger side.... sounds like right front to me tho...LOL
Old Oct 30, 2024 | 07:46 PM
7eus's Avatar
Thanks all. Front hubs are new, maybe rears are due for replacement. I’ll update if that cures it.
Edit: LCA’s are both under 10k and the bushings still look new.
Rakkasan925
Jun 24, 2021 07:37 AM
trickss
Jul 17, 2013 08:43 PM
dane
2.2L Performance Tech
13
Apr 17, 2010 08:57 PM
TiggersHHR
Jul 8, 2009 11:24 AM
HPVOHHR
Apr 28, 2008 06:31 PM
