HARD 1-2-3-od shift
Old Jun 29, 2011 | 10:40 AM
ChevyMgr's Avatar
Originally Posted by 1970judge
out of curiosity, this transmission 4t40e correct? Same thing that is in the cobalts? Just in case i want to pick up a spare one to have around.
4t45e
Old Jun 29, 2011 | 10:51 AM
1970judge's Avatar
Will there be a differentiation on the case its self so I will know what I am buying? Will it matter or not that my car does not have ABS?
Old Jun 29, 2011 | 10:11 PM
dandhcomputers's Avatar
Originally Posted by KNEZRYD
If its an 07 it has traction control.... When I first got my 06 it was doing the same thing on and off and the t/c light came on as well.... took it to the dealer and they serviced it and all was well... didn't ask the problem and now the dealer is gone... If no light is coming on I would recommend checking the fuses and relays...
You are wrong not all 06\07 hhrs have t/c it was an option .
Old Jul 2, 2011 | 08:17 PM
63falcondriver's Avatar
Our 2008 does not have traction control or any anti lock brakes. Just a plain Jane simple vehicle.
Old Jul 2, 2011 | 08:47 PM
That doesn't mean it wasn't "limp mode", the T/C light (if you have T/C) is one of the other things that happens besides the hard shift and possible CEL
Old Jul 9, 2011 | 07:22 PM
1970judge's Avatar
It did it again today, although not as bad, and finally through a code. P0011, camshaft sensor, which I read can/may cause a hard shifting experience. Hopefully that is the fix!
Old Jul 9, 2011 | 08:33 PM
mroney's Avatar
I have a P0011 also that I am working on. Don't have the hard shifting since it is a manual. But it is running rough. If that sensor goes, the timing is off. Search P0011 on this site and you will find a lot of people have run into the P0011 code. Some have changed the sensor to correct it and some have changed the camshaft actuator. I'm trying to figure out which to change first.
Old Jul 9, 2011 | 09:46 PM
1970judge's Avatar
The Code was only on for a little while, just long enough for me to scan it. It is now gone. Car was running fine, however, while it was on. I am just glad that I at least have a direction to head now.
Old Jul 11, 2011 | 01:48 AM
Originally Posted by ChevyMgr
List of P trouble codes (part 1):
DTC Description
P0010 Intake Camshaft Position (CMP) Actuator Solenoid Control Circuit
P0011 Intake Camshaft Position (CMP) System Performance
Some people have had success in getting rid of the p0011 by replacing the solenoid(s) - See posting at 05-16-2010, 01:41 PM : https://www.chevyhhr.net/forums/how-tutorial-library-21/camshaft-position-actuator-solenoid-valve-replacement-w-pics-p0010-11-p0013-14-a-28779/
Old Jul 11, 2011 | 06:17 AM
1970judge's Avatar
I wonder why the BWD replacements for those look NOTHING like the originals. The BWD parts don't even look like they will fit!
