HARD 1-2-3-od shift
If its an 07 it has traction control.... When I first got my 06 it was doing the same thing on and off and the t/c light came on as well.... took it to the dealer and they serviced it and all was well... didn't ask the problem and now the dealer is gone... If no light is coming on I would recommend checking the fuses and relays...
I have a P0011 also that I am working on. Don't have the hard shifting since it is a manual. But it is running rough. If that sensor goes, the timing is off. Search P0011 on this site and you will find a lot of people have run into the P0011 code. Some have changed the sensor to correct it and some have changed the camshaft actuator. I'm trying to figure out which to change first.
The Code was only on for a little while, just long enough for me to scan it. It is now gone. Car was running fine, however, while it was on. I am just glad that I at least have a direction to head now.
Originally Posted by ChevyMgr
List of P trouble codes (part 1):
DTC Description
P0010 Intake Camshaft Position (CMP) Actuator Solenoid Control Circuit
P0011 Intake Camshaft Position (CMP) System Performance
Some people have had success in getting rid of the p0011 by replacing the solenoid(s) - See posting at 05-16-2010, 01:41 PM : https://www.chevyhhr.net/forums/how-tutorial-library-21/camshaft-position-actuator-solenoid-valve-replacement-w-pics-p0010-11-p0013-14-a-28779/
DTC Description
