Head Lights repair
Old Mar 15, 2013 | 07:48 AM
mf3miak's Avatar
Head Lights repair
I have an odd issue with my headlights that I can't figure out and hope that one of you know the answer to my question. I noticed that the driver side headlamp wasn't on driving to work a couple of days ago, so I figured that the bulb just burnt out. Then, yesterday I noticed that when I unlock my car (key-less entry) the headlight was back on. But as soon as I turn my engine one, the headlight turns back off. The high beam filament is still okay, so I thought that the low beam filament burnt out. However, with both headlights on when unlock the car, it doesn't make sense to me.
Should I just replace the bulb and hope that fixes the problem? or would it be a wiring problem?
Thanks
Old Mar 15, 2013 | 08:06 AM
ronp's Avatar
Replace the bulb.
Old Mar 15, 2013 | 08:42 AM
Lucky's Avatar
When you lock or unlock the door it uses the hi beam side of the head lamp. Need to replace the bulb.
Old Mar 15, 2013 | 08:45 AM
jimpennjr's Avatar
When you unlock the car, the high beam filament is used. You just need to replace the bulb. Youtube has a video specific to the HHR, the video however takes of the front bumper fascia. You can also go through the wheel well. Good luck and keep us posted.
Old Mar 15, 2013 | 08:52 AM
mf3miak's Avatar
Alright, yeah at first I doubted that it used the high beam filament, it doesn't seem as bright. I'm going to replace the bulb through the wheel well, I saw a video somewhere detailing that. It will be a good weekend job haha I might as well get both bulbs replaced too, just in case in a week from now the other one decides to go out :p
Old Mar 15, 2013 | 09:03 AM
jimpennjr's Avatar
Remember not to get any type of oil (skin, grease, etc.) on the glass of the new bulb or it will burn out prematurely. Use gloves and wipe the bulb with alcohol before installing.
Old Mar 15, 2013 | 09:43 AM
mf3miak's Avatar
Okay! I rememeber hearing that during the How-To video. Thanks for the reminder!
Old Mar 15, 2013 | 06:04 PM
VinceP's Avatar
Also make sure the o-ring comes out of the socket when you pull the old bulb out. I fought with mine until I figured out the gasket was still in there. Then it popped right in.
Old Mar 15, 2013 | 09:32 PM
Lucky's Avatar
That's a really good point. I keep forgetting to warn people about that.
JRGHHRSS08
Aug 16, 2010 08:21 PM
HHRCruser
May 4, 2009 11:05 AM
Hellraisehr
Dec 13, 2007 07:07 PM
inarmywpride
16
Apr 24, 2006 05:51 PM
