Headlight problem
Headlight problem
Hi
Guys im having a problem with my headlight passenger side.
Ive changed the bulb cause it was shinig very low yellow (not bright, like in old cars with a dynamo, generator) looked like the bulb was burned out, so i changed the bulb to new ones (both sides) for new white bright light 6000k, and heres the problem, driverside shines perfect, passenger side shines like it has low voltage, after driving few kilometers, the bulb is shinig ok. Ive changed the bulb socket and checked the voltage and its ok. Any ideas what to check next ?
From your description, it sounds like you got a defective bulb. You could also check the ground wire on that side.
Option 2 would be to swap the new bulbs. Left to right. Right to left. If the problem goes to where that bulb is, then you would know it's that specific bulb that's the problem.
