Stablizer link threads
Old Aug 22, 2018 | 04:45 PM
haX0r's Avatar
Just got in some Moog stabilizer links (RK pn#'s so Chinese made). The threads seem awfully stiff (all 8 for both links). Just out of the box and running them down takes double wrenches (and the nuts get hot from the friction). Are the nuts 'staked'? (I don't have metric fine tread tap or dies to verify)
Old Aug 22, 2018 | 05:50 PM
Silverfox's Avatar
Wow .... That's a formula for frozen or stripped threads.
I put on the same ones about 5 months ago and did not have that problem.
I like Nyloc nuts with a dab of never seize on the threads if they seam tight. I usually do it a Special way.
I thread the nut on close to the stopping point and apply the never seize just on the small amount of thread left with a small brush or paper match so it does not get applied to the Nyloc portion of the nut.
Never had any problems with that type application. That would free up the nut right at the threads so you could properly torque it.
Silverfox
Old Aug 22, 2018 | 08:45 PM
You could contact your supplier and return them!
Old Aug 22, 2018 | 09:19 PM
Sounds like metric and American threads mixing it up.
Old Aug 23, 2018 | 02:15 PM
Cat Man HHR's Avatar
If you have a Home Depot, Lowes or Ace Hardware by you, you could take the link there and try sae or metric nuts on it.
Old Aug 23, 2018 | 06:32 PM
What are the part numbers? Did you cross check them against the catalogue where you got them from ro ensure they are the correct parts?
Firewatcher
May 12, 2006 04:26 PM
