Heat gauge and AC not working all of a sudden
Old Aug 24, 2014 | 12:26 PM
jesse stevens's Avatar
where is this relay located on 2007 hhr?
Old Aug 24, 2014 | 12:33 PM
LawDog88's Avatar
be more specific. Relay for what, and what are you trying achieve?
Old Aug 24, 2014 | 01:06 PM
db/sb's Avatar
Especially since the only relay mentioned had to do with one of the posters 'old Colorado' and wasn't part of the OP's solution.
Old May 21, 2015 | 08:03 AM
Happylu's Avatar
I just bought 2007 HHR LS and having the same problems with temperature gauge and air conditioner. I already replaced the coolant sensor, didn't work, so today I am having the thermostat replaced. Is this the same as mentioned in the above posts?
Old May 21, 2015 | 08:09 AM
T stat should fix the issue, ask the mech to use the correct GM stat! The ECM isn't happy with any of the other aftermarket ones!
Old Jun 4, 2016 | 02:35 AM
  #26
JTP's Avatar
JTP
Same thing happened to my wife, I found the relay in slot 15 in the fuse box under the hood was the problem, switched it with 18 to test and as soon as I plugged it in I heard the
AC motor kick on, quick trip to the auto store when its open and it will be good as new.
Old Jun 5, 2016 | 11:37 AM
  #27
JGiaccio's Avatar
The same thing happened to me this weekend. On Friday morning, the A/C quit working all of a sudden. Half way home on Friday afternoon, it came back on as magical as it quit. It worked fine all weekend, but just a little while ago, it quit again, but this time I noticed that my temp gauge is not working at all and my digital readout is dashes. I was thinking that it may be the temp sender, but someone I read changed it without being the problem, I will try the relay as JTP suggested. thank you.If for some reason the relay does not do the trick, does anyone know where the temp sensor is located? I would appreciate it. Thanks.
Old Jun 5, 2016 | 12:28 PM
  #28
If the temp gauge has flatlined, then most likely it's just a failed thermostat, I posted information in your other thread
Old Jun 5, 2016 | 09:36 PM
  #29
JGiaccio's Avatar
Thank you Old Blue, now I need to find my other thread. (I am new to this) :)
nascarguy3fan
Sep 17, 2022 11:24 AM
blue car
Dec 2, 2019 06:08 PM
rad1steve
Sep 11, 2014 05:10 PM
jay loukakis
Feb 22, 2013 06:52 PM
Senior
Sep 30, 2009 01:00 AM
