Heat shield rattle
Old Sep 27, 2019 | 02:11 PM
Jerry Juneau's Avatar
Question Heat shield rattle
My car has a heat shield rattle, diagnosed by a mechanic. This started right after I had the clutch replaced.
The mechanic who diagnosed it stated that nothing was rusted out down there but that it was loose. He said they may not be able to get the bolts off or tighten them, so he suggested a heat shield tape to hold it more securely.
the noise doesn't bother me except when I am in a drive in like at the bank. The mechanic stated that it essentially was an annoying problem but something that won't cause other issues. The things that the heat shield are protecting are secure and not moving.
Old Sep 27, 2019 | 02:33 PM
This thread has been dead for nearly three years. Are you trying to help, or do you want help?
Take it back to your clutch mechanic and have them fix their mistake...
Old Sep 27, 2019 | 02:39 PM
Moved since this has nothing to do with the 3 year dead thread it was attached to.
Many mechanics think catalytic converter heat shields are frivolous. Just don't drive or park on any surface that can burn; the cat operates at around 600F, does the title Fahrenheit 451 mean anything? (the ignition temp of paper). I got a third degree burn scar to prove it.
Old Sep 27, 2019 | 03:15 PM
Sorry. It was both a suggestion to help someone else and an issue I am having. I have no recourse with the dealership. My local mechanic stated that although everything is bolted, something is loose. To fix, I believe they would have to do a fair amount of work. They're suggested some heat shield tape to hold the part more securely. The 2006 HHR has got to be the biggest piece of junk ever made...but life goes on. Thank you.Sorry. It was both a suggestion to help someone else and an issue I am having. I have no recourse with the dealership. My local mechanic stated that although everything is bolted, something is loose. To fix, I believe they would have to do a fair amount of work. They're suggested some heat shield tape to hold the part more securely. The 2006 HHR has got to be the biggest piece of junk ever made...but life goes on. Thank you.
Old Sep 27, 2019 | 04:16 PM
If it is definitely one of the heat shields I would say "do what you want, but be aware."
However if it is really the bracket that holds the air cleaner that broke that is an easy cheap fix, either buy a used one from a junk yard or have it repaired.
2019-2006=13 years, that's 100 years in people years. I remember a time when any car was over 8 years old it went to the scrap yard.
Old Sep 27, 2019 | 05:01 PM
I was going to offer a suggestion that has minimal cost, and works great, but since you figure the 2006 HHR has got to be the biggest piece of junk ever made, I won't bother.
LT1GMC
Jun 8, 2016 05:54 AM
white08
Nov 21, 2013 04:07 AM
Vcode455
Jun 25, 2012 10:41 PM
gunwaleman
Oct 29, 2008 05:46 PM
