Heater blows cold
Old Feb 19, 2017 | 12:38 PM
  #41
https://www.gmpartsoutlet.net/auto-p...omponents-scat
Could be the actuator(s) or there have been some that found the seals failed and are flopping around.
Temp actuator,
Old Feb 19, 2017 | 12:40 PM
  #42
Jlogudce's Avatar
Well, keep us posted, hopefully it was just one last air pocket that worked itself out!
Will do.....appreciate the help 👍🏼😁
Old Feb 19, 2017 | 12:41 PM
  #43
Should the part number in the common parts thread be replaced with this one?
Old Feb 19, 2017 | 12:59 PM
  #44
Jlogudce's Avatar
So what's happening is the temperature actuator motor is getting stuck half way. I poked my head under the dash when it failed and it turns to the middle, half hot half cold (lukewarm) then all of a sudden it moves and goes to hot. I think that's where my problem lies ��
Old Feb 19, 2017 | 01:09 PM
  #45
Me too, that's the way to get to the problem, get in there and have a look. The bolts that hold the actuator are 4.5 mm
Old Feb 19, 2017 | 01:25 PM
  #46
But, is it the motor or the door sticking? Usually the door gasket gets loose/falls off.
Old Feb 19, 2017 | 01:28 PM
  #47
Jlogudce's Avatar
Well when I looked at it just a bit ago when it failed, it did move back to hot on its own. I would think to give that actuator a shot!
It will move back and forth from cold to hot if I move the knob myself (unless it's in the lukewarm where it gets stuck, then it will only move that far.
Old Feb 19, 2017 | 01:40 PM
  #48
Jlogudce's Avatar
I just pulled it off again and ran it with it hanging. It sat there and moved back and forth from hot to warm on its own on the actuator. That tells me the heater box is ok. Now it's just a matter if it's the actuator itself or the control assembly on the dash. I think the actuator is easier and cheaper lol
Old Feb 19, 2017 | 01:42 PM
  #49
I changed the part # in the parts thread. I believe Dorman also makes a replacement part, so you might be able to get it from NAPA/Advance/Zone etc.
Old Feb 19, 2017 | 01:47 PM
  #50
Yes, Dorman part number, 604-133
