Heater Resistor??
Old Dec 7, 2010 | 02:54 PM
dustindell's Avatar
Heater Resistor??
2006 HHR
Has a weird issue with the heater. The heater works on all speed settings but when you select the floor/winshield defrost mode for some reason it stays on the dash vents. If you turn the knob back and forth a bunch of times it will turn the defrost on but then kicks it off after awhile and goes back to the dash vents? Most days it wont work at all. Its getting cold and snow is on its way this weekend.
Thanks
Old Dec 7, 2010 | 04:01 PM
ChevyMgr's Avatar
You have a problem in the control head or more likely the temp actuator. No resistor is going to fix this.
Old Dec 7, 2010 | 04:06 PM
Lucky's Avatar
x2
Old Dec 7, 2010 | 07:32 PM
DaveB's Avatar
The actuator appears to work even tho it dosn't stay in position. Control unit?
Old Dec 7, 2010 | 11:47 PM
dustindell's Avatar
so your talking about the 3 knobs, one controls the temp, one controls fan speed, and one controls air directions.....?
Old Dec 8, 2010 | 10:21 AM
Lucky's Avatar
Yes, There shoud also a way to read trouble codes from the control head but I do not know how. Mabe ChevyMgr will give some insite on this?
skyeglen
Apr 24, 2023 05:09 PM
User 11223
Apr 28, 2014 08:50 PM
Dinky Toy
Feb 16, 2013 12:27 PM
Orange1
Mar 14, 2010 06:08 PM
