Help with flex pipe and TPMS
Old May 13, 2015 | 12:20 PM
Gsus's Avatar
Hi guys,
I have a leak in my flex pipe so I want to buy the part from ebay since rockauto does not list it anymore, the thing is that I have differente sizes 2". 2-1/4", 2-3/8, do you know what is the correct option for an HHR 2008 2.4lt?
also 1 of my TPS sensors was failing so I bought a new one from rockauto, but the learn process is not working by inflate or deinflate the tire, Is there another way to delete the Code nad have the TPMS working?
O I almost forgot, also the Cruise control is not working I think since the TPMS problem Do you know if it deactivate the CC?
Regards and thanks for any help.
Old May 13, 2015 | 12:53 PM
The cruise control is because of a MIL code , when my flex pipe cracked it set a code , so no cruise control, it can also be turned off due to a burnt out brake light .
I choose to replace the whole pipe $168.00 , 3 studs and 2 nuts remove and replace the O2 sensors and done , that was in April 2014 no problems since.
Old May 13, 2015 | 01:15 PM
Could you do the TPMS position thing before? Like when rotating the tires. If no, there is a tool, EL-50448 or OEC-T5, made for the job. About $80.
Old May 13, 2015 | 02:24 PM
Gsus's Avatar
sure, I did it 2 or 3 times before, by swithin on and then lock and unlock key, double bip syaing that is ready to learn, then front driver iluminated, inflate or deinflate and then a bip and so on, but now Im now having the bip when inflating the tire. :S.
for the CC I will check the stop lights.
What about the flex pipe dimension? is it 2 1/4 the correct part?
Old May 13, 2015 | 02:50 PM
Just the new one? Then you must have got the wrong TPS.
Old May 13, 2015 | 03:18 PM
2 1/4 for the 2.4 but that's by the Internet, may I suggest you measure your down pipe!
Old Nov 23, 2015 | 06:54 AM
hurst2001's Avatar
Update got the flex pipe not installed yet and know have a p0170 code for the map sensor is the due to the flex pipe being cracked ?just hoping it's not exhaust gasket were the head is...I did reset the code to see if it comes back but going to get the flex pipe installed this week..any inputs
Old Nov 23, 2015 | 07:51 AM
The flex pipe issue should resolve the code, as it can be from an exhaust leak , which would be the cracked flex pipe
P0170 Fuel Trim Malfunction Bank 1 OBDII Engine Light Trouble Code | Engine-Codes.com
Old Nov 23, 2015 | 01:57 PM
hurst2001's Avatar
Thanks old blue I know I can count on you
Old Nov 23, 2015 | 02:51 PM
No problemo, glad to help out!!
