HELP!!!!!!! Ignition/Key issue
Since you didn't bother to say what year model your's is, it's hard to tell if your car is covered under the Special Coverage bulletin. Not all year models are covered under this.
I can understand how frustrating this experience must be. If you would like me to look into anything or assist you with working with your dealership, please reach out via private message with your name, contact information, VIN, current mileage, and involved dealership.
I look forward to your reply,
Jonathan A.
Chevrolet Customer Care
I had the same ignition problem. The local dealership re[placed the ignition at no cost and the problem vanished. Another thing ... we tow our HHR with a motor home. If a certain fuse burned out the ignitrion will not work.
This is the second time ive had it repaired first time when it was still under warranty from used car lot ,so 3yrs later same thing .Took it to local dealer ship replaced shifter box no chg its a hidden recall... So if you have this problem bring it to chevy dealer.
Most registered owners received a letter from GM in 2014.
I recently had my ignition switch replaced and ever since I've had no power when I turn the key to the accessory position. I was unable to leave it again or wait that day so I left. I'm not sure if the problem is a fuse or maybe they installed a bad ignition switch. I've had nothing but problems with dealerships and hate to think I'll have to take it back to them again. Anybody have any ideas?
