Help led glow
Old Apr 7, 2013 | 08:14 AM
stelerz's Avatar
Help led glow
I replaced the map lights with led's, bright but They glow when they are suppose to be off. Did I get the wrong ones. Can anyone give me with a quick fix Not great with soldering. Also anyone know how many leds will I need for the Third brake light
Old Apr 7, 2013 | 09:21 AM
The map light deal has me scratching my head, but I'm sure someone here will chip in with a solution.
This thread should help you out with the third taillight....
https://www.chevyhhr.net/forums/appearance-modifications-discussions-6/third-brake-light-leds-32089/
Old Apr 7, 2013 | 11:27 AM
prod's Avatar
yeah there was a thread or two on here about that issue with replacement leds staying on dimly, dont remember the solution, maybe a load resistor? keep searching the forums
Old Apr 7, 2013 | 11:50 AM
Found some info on the CobaltSS forum, seems you need to put a 1-Ohm resistor on the positive contact of the LED to take care of the currant "leakage".
Old Apr 7, 2013 | 05:29 PM
I think latching may be a better term than leakage, same sort of thing though. We must remember that modern cars are digital not "on/off". In the digital world 5V may be "off" and 7V may be "on". "brake pedal position sensor" V. "brake pedal switch", etc.
Old Apr 7, 2013 | 06:01 PM
That's the term I couldn't find in my head, "Latching", thanks donbrew!
Old Apr 7, 2013 | 07:18 PM
LawDog88's Avatar
I just picked up an led of my choosing that matched the bulb at RadioShack dot com and never had a problem.
Old Apr 8, 2013 | 04:44 PM
Many of those come with a pre-installed resistor. Maybe you got one without knowing it.
bubbacharles
Mods - Interior
28
Aug 28, 2013 11:19 PM
stephenm
Mar 8, 2010 04:54 PM
roofer1976
Aug 13, 2009 02:22 PM
SIHHR
Aug 9, 2009 12:31 AM
REDFLYR
Jul 8, 2008 03:28 AM
