Hewbie
Old Aug 21, 2017 | 11:38 AM
Hewbie's Avatar
Exclamation Hewbie
My 2006 HHR with 2.4 L engine has exhibited codes (mid-week) P0114 then two days ago P0174. CE light went off by itself both times 24 hours later. What do these codes tell you ?
regards,
Hewbie
Old Aug 21, 2017 | 12:12 PM
Welcome to the site
P0114. Is related to the MAF sensor
https://www.obd-codes.com/p0114
P0174 relates to the first O2 sensor
https://www.obd-codes.com/p0174
Things to check.....
Is the MAF sensor connection tight , check the wires plugged in just up under the air filter housing
That's the wire harness, the picture shows the elbow disconnected but that's not necessarily a requirement to check the harness
Old Aug 21, 2017 | 01:28 PM
I doubt it is really P0174. The HHR does not have a bank 2.
P0171, maybe?
They both would indicate the MAF is reacting to something, either a bad MAF or more likely a broken wire.
Old Aug 21, 2017 | 01:56 PM
I'm betting, dirty MAF or ops I forgot to reconnect the connection properly.
Hewbie
Jun 2, 2012 01:22 PM
Hewbie
Tires & Wheels
May 30, 2012 10:56 PM
Hewbie
Sep 19, 2011 08:03 PM
Hewbie
Jun 6, 2011 08:11 PM
Hewbie
Jul 20, 2010 06:37 PM
