Hey guys new member here need help
Old Mar 13, 2017 | 03:45 PM
aprillucia4evr's Avatar
so I bought this 2006 HHR from my sister in law car is running ok but I pulled codes and got the following I cant seem to figure out how to fix the P0916 code
going bald trying to figure where the gear shift position sensor is or one is even
on this vehicle
p0304
p0520
p0701
p0916
p0420
Old Mar 13, 2017 | 05:02 PM
The gear position sensor is on the transmission, below the fuse box.
However, your main problem is most likely a wire frayed or burned or a fuse.
Check the ground location on the transmission near the oil filter housing. That could cause the P0916 and the P0520 and the P0701.
How is it running OK when it is misfiring? That could be the cause of the bad catalytic converter. P0420.
Old Mar 13, 2017 | 05:07 PM
I have no Idea how this car is still running fine with all those codes you could feel it missing very little but it made it from chicago to dallas and now to El Paso with all those issues
Old Mar 13, 2017 | 05:19 PM
The #1 cause of a fried catalytic converter is a misfire. P0420 means a fried converter 99% of the time.
What I meant was: it is NOT running OK, it is misfiring.
Old Mar 13, 2017 | 05:26 PM
I get you and thanks for the info I will check out that ground Im pretty sure thats the issue the bottom of the car has some rust as well as the exhaust poor thing just needs some tlc and do you suggest about the misfire does it mean the whole coil pack has to be changed? or possible just one plug
Old Mar 13, 2017 | 06:09 PM
Could be 100 different things from a hole in #4 cylinder to a loose plug.
Old Mar 13, 2017 | 07:35 PM
Welcome to the site, pull the plugs and have a look, are they all the same colour?
The Codes can be related so let's check one thing at a time , the ground needs to be clean and tight. Let's start there.
mightymouse
Feb 9, 2014 09:45 AM
longislandhhr09
Mar 19, 2009 05:18 PM
MWG2
Dec 12, 2008 02:44 PM
mightymouse
2.0L Performance Tech
16
Nov 14, 2008 08:06 PM
Money in the Bank
Feb 5, 2007 06:21 PM
