Hhr did start but engine stopped
While you have it apart, replace both the chains all guides and tensioners
https://www.chevyhhr.net/forums/how-...in-kits-60394/
Will do that eventually... Today I plan to change the oil and see if there is any metal fragments inside the oil which could indicate a damaged engine... but I think this is unlikely because the engine was running smooth.
I saw that my air filter was quite dirty. I have a question will my HHR send me a code if there is any problem with the air flow, like a malfunctioning throttle body ?
With a brand new engine, I had a P0101. After cleaning the lower TMAP sensor, and the MAF sensor, both to no avail, finally a new air filter solved the problem.
The codes don't usually point directly at the faulty part. It simply tells you that a test has been performed, and the results were not what the computer expected.
The air filter is changed. I removed the valve cover again, took off the passenger wheel and some plastic cover, I took a 22mm socket and was able to rotate the flywheel clockwise and the timing chain was also moving. Seems ok for now.
Will my HHR sent me a code if one of the ignition coil goes defect?
Also I removed one spark plug and tried to feel the air pressure when the HHR tries to start and I think the pressure is low. There is air coming out but not that much from my standpoint. I bought a compression gauge and will perform a compression test...
*installed the compression gauge inside, tried to start the HHR and the gauge pointer is not moving at all. No compression. When I place my fingers close I just feel a small amount of air coming out.
I don't see any color on my timing chain, but the diamonds seem to be positioned at 2 and 10 o'clock like in the picture. While I was rotating the flywheel at some point it felt stuck I had to use a force bar, and then it was spinning freely, until it blocked again. I don't know if that means anything. Just normal?
As for the crankshaft, do I need to remove the side cover of the engine to see?
