HHR low beam
My driver's side low beam is out. Whenever I wash my car and it is wet the low beam works. Is ther a short somewhere? Minrs is a 2010 HHR LT.
Greetings royperry.
I made your post into a thread of it's own, since it had nothing to do with the thread you posted in. |
Change the bulb.
If changing the bulb does not work like whopper suggested, it is possible there may be a short. But start with changing the bulb before you get into a whole bag of worms with tracing down a short.
Thanks guys
Welcome to the site, be sure to remove the gasket ring when you remove the old bulb, this could be due to a loose filament, so change the bulb and while you're at it, change the other side while you have the tools out and your all dirty anyways!!
Hi royperry,
Are you still experiencing this concern with your low beam headlight? Unfortunately, I am not a certified technician, but I will be glad to contact your dealership regarding your concern. Please feel free to send us a private message referencing this thread if any extra help is needed. I look forward to your reply! Kristen A. Chevrolet Customer Care |
Mine would not have a low beam while driving nbit would he on when I unlocked rhe car at night. My fix was easy.
Just wiggle the wires. the HHR is based on the cobalt / G5 which is loaded with electrical problems. |
Ahhh, that is a 3 year old thread.
Originally Posted by Justinlalumiere
(Post 818734)
Just wiggle the wires. the HHR is based on the cobalt / G5 which is loaded with electrical problems. :confused: |
