HHR overheating
HHR overheating
2010 hhr 150k miles, changed water pump, thermostat (oriellys 180 degrees), upper radiator hose, and spark plugs. Old plugs looked good no sign of water. filled radiator (using green antifreeze), will go up to 217 fan kicks on and will drop to 195 or less. I can drive it all over town not a have problem, but eventually get in traffic temp will go up as high as 230, can get out of traffic rolling down the road, fan running and temp will not go down unless turning on heater can get it to 220 or so. Not losing any water not seeing any leaks. Any thoughts or ideas?
1st thing. Wrong antifreeze. Your car is supposed to have Dexcool. That green stuff is not considered compatible in the HHR and other folks have reported temperature issues when using the wrong stuff.
You also could have an air pocket in the cooling system. If you didn't "burp" the system when refilling, that is a strong possibility.
Change to the correct coolant and then check back here.
Agree, sounds like an air pocket. I had very similar experience after flushing the coolant, until I got it burped properly. Here is our mod oldblue's burping method
And keep monitoring the recovery tank, I would say every morning for 2 weeks. George is right, the green stuff is not the best product for your engine. It only lasts a year or 2, while DexCool lasts up to 5 years, and is formulated for this type of engine.
Either jack up the right front corner or drive up on ramps or just park so the front bumper is higher then the back bumper , say on a hill, or your drive, if it inclines.
Run the car till it reaches temperature, like go for a 5 to 10 minute drive. Come back and park as I said , let the HHR cool off for a few hours, open the rad hose cap, top off the Dexcool, this can take a few tries. Start up the HHR with the cap off and see if the Dexcool goes down then top it up. Put the cap back on, tighten it up.
Check the Dexcool again next morning.
ok, i have been watching the coolant level and burped the system. I cannot find any external leaks, but the car is using coolant, i keep adding water. Spark plugs look good, oil looks good. It takes around 16-20 min before temp starts rising past the 185-195 area. I can drive it 5min, and idle in the drive way for ten min, then it will start rising. Possibly partially plugged radiator? Considering i am losing coolant, i am thinking about renting a radiator pressure tool? Any other ideas?
If you are losing coolant, that's probably why it's overheating. Some possibilities: radiator cap, trans cooler lines(inside and outside the radiator), and on or near the thermostat housing sometimes develops a pinhole. The waterpump weephole(top) and drainplug(bottom).
There's no evidence of coolant in the oil, or oil in the coolant? Maybe there was some old sealant that didn't get cleaned off the waterpump sealing surfaces when that job was done. Or the transfer tube may be leaking.
But if you can't find any external leaks, then it's likely internal. Is there no white smoke out the tailpipe? You say the plugs are good, how good? Clean like steam cleaned?
Bottom line, it's either leaking externally(as liquid or steam), or leaking internally(into the engine oil, trans fluid, or combustion chamber). It sounds like the leak is significant, you ought to be able to find it.
Here is a thread on how to flush trans fluid level. Post #1, starting at step #13, is how to check the level. If you pull the plug and a lot of greenish-reddish liquid pours out, you will need a new radiator, trans fluid flush and filter, and flush the coolant(and replace with DexCool). Here is the link
https://www.chevyhhr.net/forums/how-...-change-58325/
