HHR Panel, 2008 , Door Ajar On
Old Feb 9, 2026 | 09:00 PM
Vegasdan's Avatar
Hi All !
Have a HHR Panel 2008
Door AJAR on dash display stays on all the time as well as all the done lights. ( Had to take dome light fuse out )
Read door hatch works and displays as it should.
Checked both front door plunger switch's
Checked hood, does not remote start when ajar, it's working
Checked fuses, all ok.
Disconnected the battery and reset.
Still on.
Lubed and closed all four doors numerous times.
STILL ON !!
Can anybody HELP ????
Thank You in advance
Old Feb 10, 2026 | 07:21 AM
Welcome to the site , you don’t mention checking the rear door plunger switches, are they adjusted and working properly?
Old Feb 10, 2026 | 08:00 AM
One of your door switches is stuck in the opem position.
Old Feb 10, 2026 | 08:12 AM
He’s checked the front doors, and lift gate, rear doors are next logical items to inspect
Old Feb 10, 2026 | 08:56 AM
The tail gate switch is built into the latch. On a Panel so are the rear door switches.
87Elcamino
May 22, 2023 12:48 PM
Milton Grimes
Apr 9, 2018 05:32 AM
jarheadbobandmax
Mar 25, 2014 11:07 AM
mo650chopper
Jun 11, 2009 08:24 PM
HMSTitanic
Jun 19, 2008 06:38 PM
