HHR poor handling/goes left and right. No problems found
Old Dec 31, 2017 | 05:12 PM
Tompcomp's Avatar
Hello I'm new... and at wits end with my HHR.
2011 just over 100k miles. I bought it with 42k miles.
No wrecks. No damage or worn parts found by any shops. But the car darts left of right when it encounters variations in the roadway surface.... but it doesn't follow the crown of the road either. On a long sloping righthand turn, it wants to go straight and ride uphill into oncoming traffic. You always have to be on your game and never relax your grip or you'll find yourself in the oncoming lane or off the shoulder. Shop said there's no adjustments in this vehicle to try and correct any geometry issues. Sometimes I swear the chassis is flexing to the point the alignment changes with the pitch of the road.
This is the first electric steering car I've owned and haven't been able to test drive any others. Is this normal? (Surely, I hope not.) All steering components have been tested/calibrated.
Has anyone experienced this? Please help.
Old Dec 31, 2017 | 05:24 PM
Welcome to the site, check the lower control arm rear bushings, inner and outer tie rod ends, and hubs. It not unusual for them to wear out a that mileage.
Old Dec 31, 2017 | 06:21 PM
Not unusual for shops not to know where to look for the LCA bushings. Has nothing to do with EPS.
Old Dec 31, 2017 | 06:26 PM
Tompcomp's Avatar
Thanks, but it's been doing this the whole time I've owned it. No problems found.
Tompcomp's Avatar
Old Dec 31, 2017 | 07:14 PM
Then they obviously are not looking at the right places!
Why ask us if there is no solution according to your mechanics?
The LCA bushings are very hard to visually inspect. I have pashed inspection with totally worn out bushings.
Old Dec 31, 2017 | 07:21 PM
Ok, I'm a bit confused. It seemed like you were saying there was a problem. Maybe it's been fixed and you're warning others?
If there is still a problem... The LCA bushings certainly could have been worn out when you bought it. Unusual at that low miles, but far from unheard of. LCA bushings are not part of the steering system, so if the shop only checked steering components, then they would have missed it.
I'm also adding sway bar end links to the list of suspects, also not part of the steering, and often the first parts to fail.
Old Dec 31, 2017 | 07:31 PM
Tompcomp's Avatar
thanks for the additional info! For clarification I say no problems found, I mean no worn Parts no damage nothing broken found by the shop. The poor handling behavior is still ongoing. I will have my shop look at those things that you mentioned thank you
Old Jan 1, 2018 | 08:50 AM
These were diagnosed as ok the two piece bushing has just 40,000 miles on it.
Two piece OEM bushing in the left, replacement Moog K200792 bushing in the right. Resolved my twitchy steering issue!
Old Jan 1, 2018 | 09:09 AM
Tompcomp's Avatar
"Why ask us?" Because the handling is atrocious and was hoping to hear from this forum that there may be a known flaw... even if very rare... with these HHRs. I appreciate everyone's help. I really do. These shops test drive it and can't experience the symptoms. They inspect it and can't find any worn parts. So I'm looking for a hail Mary fix. I know at this mileage (now) a front end overhaul wouldn't be a bad thing... and I will start there.
