HHR Wanders to the left
Old Aug 25, 2006 | 07:58 AM
Firewatcher's Avatar
Originally Posted by JimZ_HHR
Mine wanders when i see a cute stud walking down the street
Old Aug 25, 2006 | 07:59 AM
We get our snow off Lake Ontario not Erie. The only sand you see here is at our crappy beach and that is littered with garbage and dead fish. Rochester isn't exactly known for our great beaches. They have the sewage plant on the other side of the street from one of our beaches. That is just plain gross!
Gee CH, I feel bad for ya. Our sandy beaches look out onto real salt water (ocean) and if you look really hard, Ireland and England.
Old Aug 25, 2006 | 08:36 AM
dan-d's Avatar
Mine didn't have any problems with the alighment with the stock suspension so yours is probably out a bit, just have it checked at the dealer.
The stock mud flaps will offer some protection which is better than none at all. As mentioned earlier they're a bit short if your car is at stock height. But if your car is lowered they come quite close to the ground and are sufficient in that regard. However, nothing beats the combination of the mud guards and running board combo. Some folks are installing after market flat mud flaps since they can be installed in any position / height that suits your fancy. Personally I like the look of the factory mud flaps because they are molded and contoured to blend with the body lines. But with that said, the after market flaps don't look trashy at all, and that's the way I would go if I didn't want to get running boards. -Dan
Old Aug 26, 2006 | 10:32 AM
robado's Avatar
I don't have any problems with the car pulling. At least not that I have noticed.
And as far as the mudflaps go. I put the same ones on that CJ did. I believe that they are truck flaps and still getting some damage from road debris. I even put them a little lower in hopes to prevent damage. I am in the works of getting the running boards. If it is this bad now in 3 months, i can't wait til there is snow,salt and st on the roads
Old Aug 26, 2006 | 04:20 PM
glenngeb's Avatar
My dealer wants $600 for the running boards. I may add the mud flaps and see what happens. The dealer swapped the 2 front tires and told me to try it. They have also ordered a replacement mirror. I will keep you all posted.
Happy HHR Motoring!
Old Aug 26, 2006 | 07:06 PM
DYLANSHHR's Avatar
Old Aug 26, 2006 | 07:46 PM
nfboy's Avatar
Originally Posted by DYLANSHHR
Gay men own HHRs too you know.
Old Aug 26, 2006 | 08:07 PM
JimZ_HHR's Avatar
and there are a LOT of cute studs out there .....
Old Aug 26, 2006 | 08:47 PM
jwolfe99's Avatar
Happy HHR Motoring!
I thought the HHR had radial tires on it??? If so why is your dealer cross-rotating them. My understanding is radial tires rotate from front to back but no cross-rotation. Ok maybe I am an old fart and not up to date on the latest tech etc. Just thought I would ask, for my own benefit as well
Old Aug 26, 2006 | 09:05 PM
nfboy's Avatar
You're confusing radial with unidirectional tires.
dustin6119
Jun 17, 2012 09:06 PM
chuckbear
12
Sep 27, 2010 08:36 AM
mitzkity
Jul 22, 2008 12:42 AM
cowboybornlate
Apr 11, 2006 05:44 PM
