High mount stop light won't turn off
https://cimg6.ibsrv.net/gimg/www.che...c57d89ead9.jpg
High mount stop light won't turn off. Any idea what could be an issue? |
L.e.d?
It is on a separate relay, maybe stuck? |
Are the other brake lights on or off?
These are regular, not led.
The other ones are off. I tried checking fuses, but couldn't locate the right one. |
Read this link: https://www.chevyhhr.net/forums/gene...rmation-61343/
It's probably wiring damage, but check the relays and such first. Wiring takes a lot of patience.
Are you the original owner? Have you looked at the bulbs, to see if they are incandescent or LED?
Look for a small box mounted on the driver side wheel well in the engine compartment. The relay is in there.
Number 3 https://cimg5.ibsrv.net/gimg/www.che...09a771a24a.png |
The lights are not LED lights.
Thanks for helping me locate that hidden box. I took the relay out and that turned the light off for now. I will order another one and see how it works out. Thanks, everyone. |
Are there any other options besides the NAPA AR606 relay?
