​​​​​​​High mount stop light won't turn off
Old Mar 13, 2020 | 04:34 PM
slonny's Avatar
High mount stop light won't turn off. Any idea what could be an issue?
Old Mar 13, 2020 | 04:39 PM
L.e.d?
It is on a separate relay, maybe stuck?
Old Mar 13, 2020 | 04:41 PM
Are the other brake lights on or off?
Old Mar 13, 2020 | 04:46 PM
slonny's Avatar
These are regular, not led.
The other ones are off.
I tried checking fuses, but couldn't locate the right one.
Old Mar 13, 2020 | 05:17 PM
Read this link: https://www.chevyhhr.net/forums/gene...rmation-61343/
Old Mar 13, 2020 | 05:34 PM
Blue_SS's Avatar
It's probably wiring damage, but check the relays and such first. Wiring takes a lot of patience.
Old Mar 13, 2020 | 06:53 PM
Are you the original owner? Have you looked at the bulbs, to see if they are incandescent or LED?
Old Mar 13, 2020 | 07:35 PM
Look for a small box mounted on the driver side wheel well in the engine compartment. The relay is in there.
Number 3
Old Mar 13, 2020 | 08:44 PM
slonny's Avatar
The lights are not LED lights.
Thanks for helping me locate that hidden box. I took the relay out and that turned the light off for now. I will order another one and see how it works out.
Thanks, everyone.
Old Mar 13, 2020 | 08:51 PM
slonny's Avatar
Are there any other options besides the NAPA AR606 relay?
