high pitch sound from wheels
Old Aug 25, 2014 | 12:13 PM
skyline26's Avatar
After braking hard yesterday to avoid an idiot who decided to change lanes without looking...im noticing a high pitched sound coming from my front passenger side wheel. I thought at first that it was my brakes since they are getting low and wore them down more than normal on that hard braking. But the sound continues as Im driving with the wheels turning and not applying brakes. Its like a "wha wha wha" sound but high pitched.
Any ideas? Thanks in advance
Old Aug 25, 2014 | 01:15 PM
LawDog88's Avatar
Hub assembly?
Old Aug 25, 2014 | 05:56 PM
Snoopy's Avatar
SOMETIMES, as you mentioned, brake pads needing replacement make a sometimes inconsistent squealing sound when driving (wear indicators). When you apply the brakes the sound stops.
Old Aug 25, 2014 | 09:50 PM
voigtsga's Avatar
+1 on the brake disc wear indicators. That would be a likely candidate given that you know that your pads are getting low.
Old Aug 26, 2014 | 06:21 AM
LawDog88's Avatar
If it IS in fact the brakes. I might recommend getting a set of Ceramic Pads.. Yes, I know, they cost more up front, BUT, they last a LOT longer. I am not an easy driver on brakes, and I just replaced hub assembly and rotated tires, and checked the pads/rotors, much much better life from the pads.
canroc
Jul 23, 2014 10:14 PM
cz9h3d
Tires & Wheels
Jan 4, 2014 07:36 PM
nacademus
Sep 12, 2013 08:28 AM
solman98
Feb 4, 2013 11:37 AM
