How do I fix the rear door - drivers side on my HHR Panel.
Old Feb 14, 2020 | 09:01 AM
For the more advanced mechanical minded.
Unbolt the door hinges. Access to the bolts via the front door being open. That should allow you to pull the door out enough to gain access to remove the door interior panel. You may have to disconnect the door wiring at the pillar.
Old Feb 14, 2020 | 09:04 AM
A spare set of hands or a jack to support the door will help in this case, be gentle the rear latch if the door won’t give you much room
Old Feb 14, 2020 | 10:26 AM
Cat Man HHR's Avatar
I found this, at the bottom of that page select "next page" also.
https://workshop-manuals.com/skoda/f..._of_rear_door/
Old Feb 14, 2020 | 10:46 AM
A close resemblance of the HHR style of hinges and wiring, , I stress again , be extra careful at the other end of the door, it’s easy to fold the door edge
Old Feb 14, 2020 | 10:52 AM
Originally Posted by Oldblue
Remote won’t over come the broken door handle problem.
No it sure won't, but my point was that it could have avoided it, using the remote..
Old Feb 14, 2020 | 10:55 AM
After Georges suggestion, I went and looked at my car, then did a Google search.
Those pictures looked like the hinges on the HHR and how it is mounted to the door and B pillar.
Old Feb 14, 2020 | 11:32 AM
Could be that he doesn't have a working fob. Which also means that the alarm system is never armed.
Old Feb 14, 2020 | 12:27 PM
SeanDavey's Avatar
Thank you FireManGeorge. That sounds like a game plan with removing the bolts. Yeah, I lost the key Fob remote a looooong time ago. The buttons on the dash do the same thing though. problem is that here in the hot Hawaiian sun, the rubber seals on the outside stick the door to the car, making it hard to open the door. I think this is why the motor stopped opening the door a while back. While I'm here, is there a way to identify the remote and replace it, maybe using the VIN or something like that?....
Old Feb 14, 2020 | 01:25 PM
This one is if you have remote start in your panel
https://www.carandtruckremotes.com/2...-remote-3.html
Old Feb 14, 2020 | 02:51 PM
After repairs are made, wipe the door seals with silicone spray. That would help w/sticking in the future.
