How to remove "beauty bar" (rear hatch opener)
Old May 24, 2020 | 09:41 PM
paulBvtn's Avatar
I don't want to break anything...
I have removed two screws.
Are there clips behind?
Or is it just stuck on with weather sealer and I need some way of carefully peeling it away? Where is the best place and method to pry it off without damaging anything?
thanks
Old May 24, 2020 | 10:05 PM
Old May 24, 2020 | 10:52 PM
paulBvtn's Avatar
Hmmm, not clear from that if nut 34 matches torx screw 17,
Is the nut additional and inside the hatch panel? (Meaning I have to take the inside panel off, which I haven't been successful with yet as the plugs are so far from the edge)
Old May 24, 2020 | 11:26 PM
17 appears to be something else. 34 attaches to the stud on the beauty bar.
Old May 25, 2020 | 03:43 AM
Cat Man HHR's Avatar
Yes, remove inside panel to get to the mounting nuts.
Old May 27, 2020 | 07:00 PM
paulBvtn's Avatar
Just to say thanks... rear trim panel is now off (found good instructions in another old thread).
Took a bit of bravery, some strength, and a lot of swearing but I'm really surprised nothing broke.
So now I can see both sides... I've decided I don't need to take off the beauty bar.
Old May 27, 2020 | 07:24 PM
I take mine off once a year in the spring to wash and clean the debris built up over the fall and winter salt and sand get between the beauty bar and the paint and the causes rust eventually.
hanover.jack
Sep 4, 2017 05:33 PM
Velocity12
Mods - Interior
Jul 9, 2012 05:08 PM
06Daytona
May 14, 2009 11:12 AM
