How to Turn Off With Stuck Key?
Old Aug 11, 2012 | 07:44 AM
TrapperJohn's Avatar
Not that it's happen to me just yet, but just preparing myself in case it does happen.
What is the best way to turn the car off if the key gets stuck in the ignition?
Old Aug 11, 2012 | 07:58 AM
ChevyMgr's Avatar
Remove either:
A) Fuel pump fuse
B) Fuel pump relay
C) ECM fuse
or disconnect battery cable
Old Aug 11, 2012 | 08:21 AM
littlefidler's Avatar
I removed the ECM fuse first and it did not kill my HHR. When I removed the fuel pump relay fuse, my HHR died when it ran out of fuel. I would recommend that you leave the ECM fuse alone as the dealer had to reflash my ECM after they replaced the cylinder lock.
Jusy my 2 cents.
Littlefidler
Old Aug 11, 2012 | 08:23 AM
Thanks Chevymgr,
So looking in the manual I see
Fuel Pump @ position 13 (underhood)
ECM @ position 41 (underhood) and position 25 (console), does it matter which one?
But, I don't see Fuel Pump Relay
Old Aug 11, 2012 | 10:06 AM
Nazgul 9
Guest
Posts: n/a
I know on my 2009 SS all you have to do is look under the steering column you will see a little piece of rubber. remove that and if you stick your finger up inside you will feeling a little rubber depression if you push this in you should be able to take the key out.. I am just not sure if this works the same for each model year...
Old Aug 11, 2012 | 01:10 PM
ChevyMgr's Avatar
You would have to of pulled the wrong fuse.
Old Aug 11, 2012 | 01:11 PM
ChevyMgr's Avatar
I believe the run/crank relay will do the trick (#51).
Old Aug 11, 2012 | 01:14 PM
ChevyMgr's Avatar
This won't help the "stuck ignition cylinder" problem. It will work on the shifter/shifter button stuck problem that was common on the 06-07 models.
Old Aug 11, 2012 | 01:59 PM
Nazgul 9
Guest
Posts: n/a
Ok Like I said I was not sure if it was the same for each model year.. Thank you for the info ChevyMgr :)
Old Aug 12, 2012 | 06:27 AM
Doctuh's Avatar
It IS the same
The mechanism is the same each model year. Only the problem is different. The override mentioned won't work with the stuck key problem. The shifter/shifter button stuck problem that was common on the 06-07 models WITH AUTOMATIC TRANSMISSIONS was due to a cheap shifter design which was improved later. It didn't affect the ignition switch itself.
