I drove my hhr about 8-9 miles with the temperature sensor unplugged
Old Jul 14, 2020 | 01:20 PM
Turner'Nichols Valencia's Avatar
Hello all... I drove my 08 2.2L HHR literally like 10 minutes up the highway without the coolant sensor bring plugged in. Before that happened my car was running hot sometimes even with a new thermostat. After getting stranded on the highway, car towed home.. It won't start.. It acts like it wants to start but the sound fades after i turn the key to start... Just had battery charged and used a scanner that didn't tell me anything. Another thing there was black smoke coming from the back lower side of the engine when i cut it off on the highway... Any suggestions at all will be greatly appreciated!
Old Jul 14, 2020 | 01:52 PM
Sounds blowed up to me. Have you ever checked the oil?
Old Jul 14, 2020 | 08:23 PM
Possibly the wire touched the exhaust pipe , that would be the source of the smoke. Did you inspect the wiring?
you could try a battery lobotomy, disconnect the negative battery cable for a full 30 minutes to reset the computers.
Old Jul 14, 2020 | 08:54 PM
Hmm
No haven't checked the wires but i did change a couple fuses related to the crank & power steering. I will have to put some oil in it... I had an oil change last month though and i don't do much driving due to the pandemic etc... But i looked under the oil cap it looked extremely dry... Though the dipstick was wet... I had the battery charged yesterday do i still need to disconnect it?
Old Jul 15, 2020 | 07:39 AM
To reset the computers, yes.
if it was low voltage, and you charged it , where did you connect the battery charger? Under the hood? Or in the back at the battery?
Old Jul 15, 2020 | 08:04 AM
The battery in the back...
Old Jul 15, 2020 | 08:20 AM
Cat Man HHR's Avatar
If you could smell the black smoke. What did it smell like ?
Did the car backfire or buck when it happened ?
Old Jul 15, 2020 | 08:22 AM
What wire would be that ?
Old Jul 15, 2020 | 08:31 AM
"I drove my hhr about 8-9 miles with the temperature sensor unplugged"
I'm still waiting for an explanation to this. As in Why and what for ?
"I will have to put some oil in it... I had an oil change last month though and i don't do much driving due to the pandemic etc... But i looked under the oil cap it looked extremely dry... Though the dipstick was wet..."
Put oil in it ? Why ?
Oil cap looked dry. (yes it should but what does that matter)
Dipstick was wet(again. means nothing. How was the oil level ?)
Honestly. Find a good mechanic to help you out. No offense but from reading your posts it's obvious you don't know anything about cars and how they work.
Old Jul 15, 2020 | 10:39 AM
The coolant temp sensor wire that was left unplugged, CatMan
