I think my water pump is gone....
Old Oct 15, 2009 | 04:04 AM
masterchief1112's Avatar
i know its not a common issue but i was driving home and noticed my temp was climbing past normalso i said hmm i hope its just a fluke. when i got home i decied to check te thermostat. draind some fluid took that bad boy out and not a thing wrong with it. so i topped off the coolant and started her up. i can heear a grinding noise coming from the general location of the water pump. well i guess its off to the service station tomorrow(today).
Old Oct 15, 2009 | 08:07 AM
unique_w's Avatar
Water Pump
How many miles are on the vehicle ?
Originally Posted by masterchief1112
i can hear a grinding noise coming from the general location of the water pump. well i guess its off to the service station tomorrow(today).
Old Oct 16, 2009 | 05:49 AM
60k got back from service, it was the water pump, the impeller ate itself. 500 bucks said and done
Old Oct 16, 2009 | 06:41 AM
ChevyMgr's Avatar
This should have been free under the powertrain warranty.
Old Oct 17, 2009 | 05:09 AM
dealer was being a pain and was insisting that i had to pay a 500 buck deductible, i didnt want to deal with it at all and took it to the shop that i usually go to. they sometimes do gm warranty work when the dealers are swamped so he is trying to get some of the money reimbursed.
Old Oct 17, 2009 | 09:26 AM
unique_w's Avatar
Water Pump
Were there any signs of a coolant leak prior to the grinding sound ?
Water pump failure is common some start failing at around 40k, but can fail at high miles. They usually fail in one of two ways: the bearings fail or they begin to leak (seals or gasket). It’s possible to have a leak from a cracked water pump. The low-pitched grinding sound is a key sign and/or a coolant leak.
Old Oct 18, 2009 | 04:54 PM
no sign of coolant leaking whatsoever, further investigation into the pump, looks like the shaft was worn and to me looks like it went off balance and came in contact with the side of the housing.
Old Oct 18, 2009 | 06:38 PM
ChevyMgr's Avatar
If the dealer quoted you $500 you need to call the service manager and complain. It should have been fixed for free. Tell him you want a refund.
Old Oct 19, 2009 | 03:47 AM
done
beltrunner
May 5, 2015 09:28 AM
donbrew
Jan 21, 2013 08:00 PM
ebritt
Jun 12, 2012 05:12 PM
wagoneer
Jan 12, 2010 11:17 AM
