Ignition Problems
Old Aug 20, 2013 | 08:35 PM
nuisance5's Avatar
Ignition Problems
Has anyone had a problem with their key not wanting to come out of the ignition? My started in my 2006 HHR about a month ago. It is intermittently but occasionally it will turn back to the accessory point but won't go to the point where you can remove the key. My husband also said that the steering doesn't seem right to him especially if you are trying to turn sharply parallel parking.
Old Aug 20, 2013 | 08:44 PM
You are new. Look up at the top of the page, just below the main banner. There lies the "search" tool, which will search this forum for you and provide 6 or 7 pages of possibilities.
That "search" button is brand new to the board, and it works!
Old Aug 21, 2013 | 06:01 AM
Ron S's Avatar
Welcome to the forum. There was a recall for an ignition cylinder replace because of stuck keys. I don't know if it aplies to the 06. Check with your local dealer. We have a 09 and a 10. I hope this helps.
Ron
Old Aug 21, 2013 | 11:48 AM
hurst2001's Avatar
Also there is a slot were it is under the steering column it is a small plastic square you can pop out and put your finger and find the white plunger on it push in and you can remove the key.. Anyway it has to do with the shifter not engaging to release the key ,either that the ignition switch is bad ,both are cover under warranty if not mistaken .. my 07 did the same thing..
Old Aug 21, 2013 | 01:16 PM
ymerej_mortsdnil's Avatar
Thumbs up just happened to us yesterday...
Our key got stuck in our '09 LS (manual transmission) last night...my wife came home from work, couldn't turn off the car. We drove to the nearby Chevrolet dealer where they kept the car inside all night after killing it since it is a manaul transmission.
Got a call at 10 a.m. this morning that the car was repaired, it was an ignition lock cylinder & covered under a recall by Chevrolet! NO CHARGE! GREAT SERVICE & back on the road in a little over 12 hours!!
shybull
GM Recall Campaigns
43
Dec 22, 2014 10:02 AM
Cokeybill
GM Recall Campaigns
Aug 19, 2014 09:42 PM
JimDaddyo
GM Recall Campaigns
28
Jun 5, 2014 01:13 PM
LeslieMaxwell
Dec 19, 2013 07:36 PM
Benjamin
Dec 4, 2012 04:19 PM
