Ignition switch cylinder went ka-put!
Old Feb 14, 2012 | 08:57 PM
ChevyMgr's Avatar
Originally Posted by Snoopy
INTERESTING you would post a statement and NEVER RETURN for any type of response !!!
I guess he got it off his chest and felt better.
Old Feb 18, 2012 | 08:44 AM
rainmanva's Avatar
this happened to me several months ago, i bought my 2010 hhr used in may 2011 and the key clyinder failed in september. luckily, it was under warranty. my dealer treated me good, changed it and i was out the door within two hours. i was like oh no, car isn't even six months old and im already having problems!
Old Feb 18, 2012 | 09:12 AM
db/sb's Avatar
Originally Posted by rainmanva
this happened to me several months ago...
What happened, you posted a statement and didn't return for any type of response?
But seriously:
.....i bought my 2010 hhr used in may 2011 and the key clyinder failed in september. luckily, it was under warranty. my dealer treated me good, changed it and i was out the door within two hours. i was like oh no, car isn't even six months old and im already having problems!
The car is more that six months old, it's a 2010. The cylinder problem is farily common, fortunalely, you were able to get it repaired under warranty. What other problems are you having?
Old Feb 18, 2012 | 01:14 PM
rainmanva's Avatar
none, i was just posting that i was repaired by dealer under warranty. because it was gm certified i got 12 month 12,000 mile warranty from dealer.
Old Feb 18, 2012 | 01:47 PM
Don06's Avatar
I lube the locks every time I change oil. Most locksmiths sell the spray lube for this purpose. Graphite or moly lubes that don't leave a sticky residue work best. Don't have a bunch of keys on the ring with the vehicle key either.
Old Apr 17, 2012 | 07:12 PM
  #26
ghostdragon's Avatar
Stuck key
This happened to me April 13th, 2012. I stopped to get gas and put the car in park. The car would not turn off. I popped the little cover under the steering wheel and could not get the lever to release the key.
Called Ford dealership where I purchased it used. They told me to bring it to them which is 40 miles away. 3 mechanics could not get the key out. (one is a previous GM mechanic.) The car was still running when I left.
Yesterday the service department called and told me the cylinder had seized up and it was covered by the extended warranty from Ford that I had purchased. Also, the key was bent and they had to give me a new key.
Today I picked my car up and paid my $100 deductible, instead of the $385 on the invoice. Started my car to come home and the engine light did not go out. I went back in to the service department and told them the engine light was on. The service guy told me that GM told them it would reset after a few cycles. Is this normal or not? I do not see why it would have to go thru a couple cycles to go off.
I told him if it does not go off I will be calling and bringing it back to them in a day or two.
Old Apr 17, 2012 | 07:19 PM
  #27
solman98's Avatar
Originally Posted by Putter
Now I can just pull it out about an inch and the chimes stop.
That's how my 06 is since new. Weird. Wonder if they changed it on the later models?
Old Apr 17, 2012 | 08:09 PM
  #28
87silver's Avatar
Usually a pending code will clear itself in 3 cycles if the root code does not return. This has happened with my GMT325 vehicles (Chevy S10 & Olds Bravada) and the code cleared as expected (engine light went off by itself). This was PD PO300 (Random misfire). Coincidentally I had the same code once with my HHR and it would not clear by itself, I cleared it with a scanner and it never returned.
Old Apr 17, 2012 | 08:16 PM
  #29
Ok, thanks for the info! Since they are 40 miles away if the code does not go away I guess I will ask my boss to clear the code for me.
I work in a hydraulic repair shop and we have a few scan tools.
Old Apr 17, 2012 | 08:17 PM
  #30
Stupid question of the day....what determines a cycle?
