The infamous "ENG PWR REDUCED"
Old Feb 22, 2009 | 12:29 AM
08BlkSS's Avatar
Just got home early Saturday morning from a 1 day road trip and on the way home mine did the same thing. Just passed 10K miles. After about 10-15 min of driving I could feel it start to act normal again so I stoped every 50-60 miles to turn the car off for a few min and restarted it to see if I could get the light to go off. It appeared that as long as the check engine light was on i had an effect on the gas mileage. Finally after a couple hours the light finally went off. Car acted fine rest of the ride home and the light has been off since.....
Old Feb 22, 2009 | 03:28 PM
Jdans431's Avatar
i did some drivin around town today just for the kicks of it and the light has not been on at all today, and no probls. If it stays off, I am canceling my appt tomrw
Old Feb 22, 2009 | 04:11 PM
kornellred's Avatar
Jdans431 - please keep the group posted on what happens - the "engine power reduced" message does not appear unless there is a fault somewhere. It's definitely best to take it to the dealer when the CEL is on and the fault codes are present. I had the same message with my HHR and the first time I took it in (after clearing the codes myself) the dealer could not find anything wrong. If there is a real problem, it will get worse to the point where you will not be able to drive yours. In my case, there was a bad electrical connection. The dealer had to find it to fix it, because, eventually, driving my HHR was not possible. Good luck!
Old Feb 22, 2009 | 05:18 PM
IgottaWoody's Avatar
Take it to Auto Zone and get a FREE scan,,THEN go to the dealer and see if they match!
Old Feb 22, 2009 | 05:38 PM
Jdans431's Avatar
Im gonna keep an eye on it. Im sure it will come back, I will take in soon. I want to see if it keeps happening over the next few days. I was almost empty on gas so I filled up with better gas and added fuel injector cleaner. Lately I have been buyer cheaper gas, which it may not have liked.
All the reading I did on this topic, some have serious problems with this messaage and some make it sound like it self corrects. I saw everything from clogged fuel injectors, variance in accelorator linkage and electrical as you said. We'll see what happens this week. Got a lot of driving to do this week
Old Feb 23, 2009 | 12:59 PM
Jdans431's Avatar
So here it is. After the light staying off yesterday, I drove to work today and the light came back on and the engine power reduced message came back with a vengance! By the time I got to work I felt like I was in a salt shaker, the car was vibrating so badly. I had the car towed to my dealer using Chevy roadside assistance. Turns out I need a new throttle body. They should have it done tomrw.
I was pleasantly surprised that the warrenty covered the tow and the rental car that I am going to get later today. Should have my car back tomorrow night.
Old Feb 23, 2009 | 02:07 PM
masterchief1112's Avatar
glad yo got it fixed
Old Feb 23, 2009 | 04:49 PM
Jdans431's Avatar
stopped by the dealer on the way home to pick up my rental car, and I was give an Cadallac SRX.. man this thing is nice, im not sure I want to give it back
Old Feb 24, 2009 | 09:22 AM
FallRiverHHR's Avatar
Well, a bit of an update. This past weekend I brought my car in the the used dealer I bought it from two weeks ago to have the safety sticker updated (it was 4 months old). I asked them to check the codes, as the car has been progressively getting worse.....after the first time I had the issue, the CEL went off and everything was fine, but now sometimes it comes on almost instantly after I start the car and get moving, and other times I can drive for a couple of hours with no issues. The fact that the fault is intermittent tells me it's likely a wire going to ground somewhere.
Anyway, the dealer hooked the car up, and sure enough, it's throwing the codes indicating the Throttle sensors. They're ordering a new throttle body for me, but I'm going to be adamant that they check the wiring harnesses as well. This morning on my way to work, it felt like I was trying to accelerate by pushing molasses through the fuel injectors. It's dangerous if I'm pulling out into traffic, and then can't accelerate fast enough to keep up with the flow of traffic. I am pleased however with the fact that the used car dealer didn't even slightly hedge on fixing the problem: they acknowledged that they would do whatever it took to make it right, even though they could have just requested that I bring it to a Chevy dealer for the warranty work. Good on 'em!!
Old Feb 24, 2009 | 09:53 AM
Jdans431's Avatar
Same problem mine is in for right now. Glad to hear they are taking care of you.
