Interm. Hard Starting
mine has done it a dozen times or so in the last 15k miles, but I attribute it to not actually holding the key in the cranking posistion long enough and the ECU taking control and keeps cranking until it starts.
Its nothing bad really, it always starts anyways.
Hard starting
I have the same issue with our 2.4
It goes to the dealer tomorrow for this issue and an oil change. Thanks for the posts, hopefully they will fix it. It sounds like the fuel pump issue.
Don
Don
I have heard that if you continually run your gas level down to empty, (less than a 1/4 tank) it will effect your fuel pump.... any comments on this?.... I had a 2001 GMC Jimmy, which i used to continually run till almost empty and i had to change my fuel pump last year.
They rescheduled our appointment for the starting problem. We havea couple of other issues, like poor radio reception (there is a TSB on this) and also some of the seal around the windshield is screwing up.
I will keep this thread posted on what they fix on ours..
