Interm. Hard Starting
Old Jul 31, 2006 | 11:16 PM
  #41
pontfirebird73's Avatar
mine is actually getting worse and I am taking it in tommorow. I guess I will be driveing my 73 firebird for a while.
Old Aug 4, 2006 | 07:24 AM
  #42
Firewatcher's Avatar
It's happened to me twice this week. Wonder if it's a temperature or a/c issue. Never happened when the weather was cooler. Also have developed an a/c "grinding"? noise. Time for a check-up!
Old Aug 7, 2006 | 09:18 PM
  #43
CHV_FRK's Avatar
Well... no TSB yet... They thought there was, but alas there is not. I'm still waiting for my pump....It's been a week thus far!
Old Aug 25, 2006 | 12:08 PM
  #44
Navyflyer11's Avatar
Any news on this issue. I would like some info befor I go to the dealer.
Old Aug 25, 2006 | 12:29 PM
  #45
Update - I had mine checked while at the dealer this week. No codes printed, unable to duplicate. It only happened once so I don't think I will dwell on it any longer.
Old Aug 27, 2006 | 06:45 AM
  #46
kitt113's Avatar
Hard Starting
I bought my HHR in February, and I am loving it. But I am having a problem with the vehicle starting. It starts sometimes with the ignition key and the keyless fob, but it's like it continues unto a longer start than usual sometimes it does not start and sometimes it does. First time I took it back they replaced the keyless fob. Took it home and the same day it did it again, so I gave it some time figuring it would correct itself. Took it back again, for the same problem, my husband, niece, a friend, they all heard it do this, but the dealer could not replicate what it had done, so I have it back again, and it does it from time to time. I have my husband's camera and put it on video each time I get in the vehicle and guess what it does not do it, but it has happened when I forgot to turn the video on. I wanted to give proof to the dealer, so they would believe me, I guess I will continue doing this. I was thinking they were trying to wait until the warranty runs out, but I have the Elite Plus warranty so its on the vehicle up to 100,000.00 miles. Any suggestions as to what to do next? I guess just keep running it? I am afraid it will mess the vehicle up eventually. Thank You!
Old Aug 27, 2006 | 10:11 AM
  #47
thedonn007's Avatar
It is my understanding that this issue is due to the fuel pump loosing its prime and there is supposed to be a TSB issued for this. I think you would want to get it corrected as soon as possible since it is putting more wear and tear on your starter. I am experiencing the same issue, but I have not taken my car in yet either. There seems to be no ryhme or reason to when the hard starting happens either
Old Aug 27, 2006 | 11:09 AM
  #48
jaysz2893's Avatar
i took mine in and they could not replicate the issue. Suprise! Anyway, it is driving me nuts. AS is the leak that they "fixed" too. I dont balme my dealer, but GM corporate needs to step it up a bit and either fix the proble the 1st time or replace the poblem all together..
Old Aug 27, 2006 | 02:21 PM
  #49
kitt113's Avatar
Can you tell me what a TSB is? Does this come from the dealer or GM. I guess I will try to catch it doing it on video,and then maybe they will believe me but I doubt it since they have to replicate the problem. No error codes came up on it either. They kept it overnight because I thought well maybe the cold start would cause it to do it, but no it did not. Like you said I have no idea when its going to do it. Well I guess I will keep running it until I get it on video so they can hear it. Thanks.
Old Aug 27, 2006 | 02:23 PM
  #50
kitt113's Avatar
I just noticed I replied back to the wrong person, but hopefully you can still help me with the TSB. Thank You.
