Intermediate shaft bolt
Old May 20, 2021 | 12:07 PM
UnknownError's Avatar
I knew that my intermediate shaft needed to be replaced to get rid of the rattle but I also had some loose steering. My research led me to the intermediate shaft didn't effect the steering so thought I had it narrowed down to the tie rods. After removing the tie rod end from the steering knuckle it seemed pretty solid, both outer and inner. Started looking around and noticed the the bolt to the intermediate shaft has sheered off halfway. If I order a new shaft will it come with the bolt? P.S. this probably happened when I slid into a curb when icy.
Old May 20, 2021 | 01:02 PM
My replacement shaft included new bolts .
is there thread on the other side? You may have to drill that out.
Old May 20, 2021 | 01:14 PM
yes the threads stick out on the other side. I was thinking I wouldn't have to remove it and just replace the whole shaft and use the new bolts. It broke past the "split" so when viewing it you cannot see the bolt in the slit, only on that one side so it shouldn't be too much trouble to remove. I didn't think about turning it for a better picture
Old May 20, 2021 | 03:10 PM
So long as the remnants of the bolt aren’t blocking the notch on the steering rack input shaft, then yes you should be able to drive it up with a punch or chisel
Sturgell
Apr 12, 2020 06:44 AM
Oldblue
Maintenance and Upkeep
16
Nov 1, 2017 09:18 AM
webpirate
Jan 8, 2016 01:42 AM
1970judge
Nov 14, 2011 07:15 PM
1970judge
May 7, 2010 10:52 AM
