Intermittent hazard lights when hitting bumps
Old Oct 27, 2024 | 07:13 AM
Oldsman's Avatar
My friend had it at a shop in Kansas City. They're saying it needs a BCM. What's the procedure to test the BCM? He's coming home this weekend so I might be able to check it first hand. I will be checking the wiring first in any case.
Old Oct 27, 2024 | 07:22 AM
Rarely does the BCM fail. Or the wiring, the switch would be first to inspect and test.
Old Oct 28, 2024 | 12:10 PM
The switch/sensor sends a ground signal to the BCM. That triggers the hazard lights.
The switch/sensor sends either a "open" off, or a "ground" on. There is no positive voltage involved.
I don't know how the BCM could possibly be at fault
Old Oct 28, 2024 | 12:19 PM
Oldsman's Avatar
Thank you. I have a replacement switch in hand. I should be able to get it installed tomorrow.
corivus
Jul 19, 2019 05:32 PM
hurst2001
May 30, 2016 12:04 PM
volcycle
Oct 12, 2008 08:34 PM
ballplr
Mar 12, 2008 07:43 PM
rdd
May 11, 2006 01:43 PM
