intermittent no crank or start
Hey there, I just recently bought another HHR. It's a 2006 LT 2.4L. The first couple days it was fine. Now I'm getting an intermittent no crank no start issue. I think the security symbol comes on when this happens. Eventually the light will go out and it will start and run fine. Is this common? What would the fix be? I have been searching for hours and can't find an answer. Any info would be greatly appreciated. Thanks.
Well after trying a bunch of things that seemed to work for a few days at a time, I think I finally found out what the problem was. I took it to my buddies shop and he scanned it. It had 3 codes. The 3 codes indicated some interference between the key and transponder. It turns out it was my cell phone charger that was mounted to the vent was to close to the ignition. When it was charging it interfered with the transponder. If I put my phone in the charger before I started the car, the security light would come on and not crank. This was a new one for me. Thanks for the info guys.
sail414
May 25, 2009 10:06 AM
