P1682 code. crank but no start
Old May 10, 2015 | 02:57 PM
FatTireBiker's Avatar
as the title says.....any help?
Old May 10, 2015 | 03:10 PM
Googled it: P1682 Chevrolet Ignition 1 Switch Circuit 2 OBDII Engine Light Trouble Code | Engine-Codes.com
Old May 10, 2015 | 03:35 PM
Yeah I got that far but that didn't get me very much with solving the problem. Thanks
Old May 10, 2015 | 04:45 PM
Snoopy's Avatar
Well since the link provides information on 2 different fuses, I would start there. Your owners book has a listing of the fuses and locations.
Old May 10, 2015 | 06:03 PM
Gee; 2 fuses, 1 relay, 1 switch, TAC or the ECM. That doesn't help? Did you scroll down to the bottom:
There are 2 ignition 1 voltage circuits supplied to the Engine Control Module (ECM). The first ignition circuit is provided by the powertrain relay, through a fuse. This ignition 1 voltage circuit supplies power to all the internal ECM circuits associated with the throttle actuator control (TAC) operation. The second ignition 1 voltage circuit is supplied by the run/crank relay through a fuse, and is used to power the remaining internal ECM circuits. If the ECM detects a voltage difference between the 2 ignition 1 voltage circuits, DTC P1682 will set.
Read more: P1682 Chevrolet Ignition 1 Switch Circuit 2 OBDII Engine Light Trouble Code | Engine-Codes.com
Sounds like an exact way to diagnose & the solve to me. My money is on the TAC not being plugged in correctly.
Old May 10, 2015 | 06:30 PM
Have you had the ignition switch recall done?
Old May 12, 2015 | 11:43 AM
Thanks everyone for the help and info. I found my stupid mistake...Cam Solenoids in the opposite holes.
Old May 12, 2015 | 11:54 AM
That'll do it. Glad you got it resolved.
Old May 12, 2015 | 03:39 PM
Snoopy's Avatar
Would have been helpful if you told us you just performed the mechanical work and the car wouldn't start.
But I'm glad it worked out.
Old May 12, 2015 | 05:05 PM
x2.
Marush
Jan 16, 2015 12:23 AM
Snoopy
Jan 18, 2014 10:31 PM
jm9678
Jan 10, 2014 06:22 PM
Sparky21440
Mar 26, 2011 08:41 PM
goetylsd
May 11, 2010 10:32 PM
