Intermittent starting and dashboard sporadic
Old Jun 13, 2025 | 01:56 PM
PulpFriction's Avatar
Originally Posted by Oldblue
K, I see that now. And 12.3 is a low battery, it might also have a dead cell or 2
Could be. Typically a single cell (one of 6) shorted by sulfating will rather quickly (anywhere from a few minutes to a few days) cause the voltage to drop to 5/6 or about 83% or about 10 5V. I'm no expert on lead-acid batteries so I don't know what other causes rhere are for a "dead" cell. I do know that even a bump during mishanding can cause hidden damage.
Old Jun 13, 2025 | 03:24 PM
Mooch's Avatar
The shop tested the battery and got 12.77V, and my voltmeter reads it at 12.54V, and the battery is from January of this year, so it very unlikely to be a battery problem. I was able to find and test the connector and pins for the BCM and this is what I got: With the battery disconnected, the connector side (the wires to the BCM) gives me 120 Ohms, which is expected because double checking at the OBDII connection it is also 120 Ohms, meaning that the BCM has one of the two terminating resistors. However, when reading the pins on the BCM itself, it is 50 Ohms, when it should be 60. Very odd.
Old Jun 13, 2025 | 07:30 PM
jimvw's Avatar
alternator?
Old Jun 13, 2025 | 09:15 PM
Seems like a connection on the BCM. The interior lights are controlled by the BCM.
Old Jun 14, 2025 | 08:19 AM
I would agree if it’s not self discharging. Easy to test for that; leave it disconnected for a couple of days.
Kingav120
2.4L Performance Tech
Jan 12, 2022 12:55 AM
john11
Aug 28, 2020 07:26 PM
j67
Jul 14, 2020 08:16 PM
Ms.Washington
Dec 19, 2018 07:39 AM
Cassidy Sunday
Dec 11, 2017 10:15 AM
