Intermittent strange behavior
Old Jun 7, 2021 | 11:03 AM
twotimers79's Avatar
Every now and then, while we are using the car, it begins to run very rough, the instruments go haywire, power steering goes off. Usually if we park , remove the key, and let it set awhile, then restart, it cures the problem. However, sometimes it can take several hours or days to respond.
Old Jun 7, 2021 | 11:19 AM
Since you don't say the year, model, engine size, mileage, how long owned or any repair history...... I'll take a very wild and vague guess.
Bad battery or connection.
Old Jun 7, 2021 | 12:53 PM
Yes, low voltage, that would be my first thing to check. Your local auto parts store should be able to perform a free battery load test and charging system test.
to the forums!
Old Jun 7, 2021 | 01:00 PM
X3 ^^^^^^
Old Jun 7, 2021 | 11:11 PM
It's a 06, big motor, and lots of miles. I realy don't think it's a battery problem, have not had any trouble starting. I was thinking more along the lines of a computer glitch since it seems to "reset" itself after being turned off and key removed. Sometimes it happens again after a couple days, and other times it may be weeks between incedents. Am I totally off in that speculation ?
Old Jun 7, 2021 | 11:50 PM
Yes, you may be totally off. Did I mention that the testing is free?
Yes, I did.
Big motor? Are you even talking about an HHR?
Old Jun 8, 2021 | 06:29 AM
‘06, 2.4 , symptoms indicate low voltage, it might start, but not enough voltage to run the computers while running. 12.4 volts or less is a battery problem! Possibly a dead cell
Old Jun 8, 2021 | 08:09 AM
Or, the big red wire on the fuse box.
Old Jun 8, 2021 | 08:44 AM
No Don, we are wrong. . The OP said it can't be the battery/voltage/connection. It MUST be that computer (post #5)
Old Jun 8, 2021 | 09:34 AM
I wonder if this is another case of "the CEL has been on for a long time, I didn't think it was important t mention".
